• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    Subassembly Composer - Tutorial ?
    1670 Views, 3 Replies
    04-27-2012 12:54 PM
    Does anyone know of a website that can provide a tutorial on the SubAssembly Composer? Maybe something in Autodesk University site? I can't seem to find anything and the wiki help is pretty lean on how to get this potentially great tool to work. Thanks Chris
    Please use plain text.
    KMercier_C3D
    Re: Subassembly Composer - Tutorial ?
    04-27-2012 01:01 PM in reply to: chierchio
    There were two classes specifically about Subassembly Composer at Autodesk University 2011:
    http://au.autodesk.com/?nd=class&session_id=9196 and http://au.autodesk.com/?nd=class&session_id=9212
    Kati Mercier, P.E.
    Co-author of "Mastering AutoCAD Civil 3D 2013"
    AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
    AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
    AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
    Valued Contributor
    04-27-2012 01:08 PM in reply to: KMercier_C3D
    Thank you so much for the links! Looking forward to the tuorials. Best Regards, Chris
    Employee
    04-27-2012 01:09 PM in reply to: chierchio
    There were two classes at AU last year on this, one by myself and a very detailed class by Kati Mercier that you should check out. We both did an hour of how to get started with Subassembly Composer.
    We also have a number of sample Subassemblies on the Help Wiki site that you could look at for starting points.
    Cheers,
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
