AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Subassembl y Composer - Stripping surface tool
- Highlight
- Email to a Friend
- Report Inappropriate Content
Did you add this slope link in your Assembly design in Civil 3D or did you have this built right into your custom SA? I'm thinking it's likely just required on the outside of the stripping SA.
I need a slope link on both ends (it's not crucial mind you). What we need is the stripping from the edge of the shoulder to the end of the daylight (ditch or side sideslope). I have built it so I can set the offset from C/L or target a feature for the inside of the stripping. For the outside of the stripping i've done the same thing. What I'm not seeing is how i can build into the custom SA a tie-in of a slope link to the target surface.
Thanks.
- Highlight
- Email to a Friend
I can see two ways to do the closing link. One would be to add a link from the end of the stripping link to the OG surface. This would make a link that would close beyond the daylight point. The second option would be to add a link from the daylight point back towards the centerline down to the stripping depth and then add the stripping linke between the EOS and that point.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
