AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Subassembl y Composer - Stripping surface tool
- Highlight
- Email to a Friend
we are missing tool in SAC for stripping a surface exactly the same way how Stripping Pavement or Striping TopSoil works. There is no tool to copy and vertical offset part of the surface. I found out some workaround with Point Delta X on Surface and then vertical Offset, but this is very complicated and I am not able to follow each peak of the surface. Do you have any effective idea? Surface link is not suitable for Topsoil stripping.
Martin
Re: Subassembl y Composer - Stripping surface tool
- Highlight
- Email to a Friend
exactly wt kind of strriping do u want? could u elaborate?
Civil 3D 2013
HP Pavilion dv6 cor i7
16GB RAM
windows 8
- Highlight
- Email to a Friend
I need several topsoil strippings integrated in my own subassembly.
thanks
- Highlight
- Email to a Friend
Why do you say that a Surface Link is not suitable for topsoil stripping?
A Surface Link allows you to pick the surface to follow, define a starting X and an ending X (along with the ability to reference offset targets), and then select what the vertical offset from the surface is that you define.
Is this not what topsoil stripping would need? If not maybe you can provide a sketch of what you are looking for?
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
- Highlight
- Email to a Friend
Hi Kati,
here it is, what we need...
- Highlight
- Email to a Friend
As Kati pointed out, that is exaclty what the surface link was designed to do. It will follow a surface between two points and with an optional vertical offset.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks Peter and Kati,
I made a fool of myself little bit... Maybe the picture in SAC help should be more illustrative. It is not clear, if there is one link (segment) or more segments of stripped surface.
Martin
- Highlight
- Email to a Friend
Here is a subassembly that has one "Surface Link", it segments it to match the surface. Hopefully this visual helps. (The far left side has a separate link for a slope to surface.)
- Highlight
- Email to a Friend
Thanks Kati, this is quite clear example and good tip how to "close" the stripping.
Martin![]()
- Highlight
- Email to a Friend
Since it's already built, and it's so simple would someone like to post it in 2012 version?
