• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    LeafRiders
    Subassembly Composer - Conditional Cut / Fill above or below surface?
    146 Views, 1 Replies
    11-05-2012 03:53 PM
    P1.DistanceToSurface(SurfaceTarget) - Vertical Distance from point P1 to SurfaceTarget (Point above = positive, point below = negative). The above is the reference that I'm using... So in the Condtion value I've entered the following expression, am I getting this right or NO?
    AP1.DistanceToSurface(TargetSurface)>=0
    False = Cut (below TargetSurface)
    True = Fill (above TargetSurface)
    Looking for some confirmation on if this is the right method to the madness? Thanks in advance.
    Please use plain text.
    Employee
    Re: Subassembly Composer - Conditional Cut / Fill above or below surface?
    11-06-2012 05:43 AM in reply to: LeafRiders
    That looks correct. What I do would do if I wasn't sure would be to add a point to the true side and then move the target surface inside of SAC up and do and make sure that it appears/disappears the way I expected.
    Cheers,
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
