• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Sub Assembly Composer Expressions
    400 Views, 5 Replies
    07-08-2011 12:31 PM
    Does anyone out there have a good site that would show how to write VB expressions for the Sub Assembly Composer??  I am new to writing expressions and need a little help.
    Jay Meszar
    Please use plain text.
    Employee
    Re: Sub Assembly Composer Expressions
    07-11-2011 06:28 AM in reply to: Jay.Meszar
    Jay,
    There are some great examples in the help file, but if you need more let us know what you are trying to do and we'll see if we can help. I find that for the most part the expressions that I use are pretty simple... P1.X for example to find the x offset of a point.
    Cheers,
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    Member
    makile79
    02-10-2012 01:35 AM in reply to: peterfunkautodesk
    can I in SC point  take over slope from other point?
    point 2 slope = superelevation
    point 4 intesection slope  point 2 and 3
    point 2 slope 1:2
    point 3 slope = superelevation
    is there a record for point slope like as P1.x for x axis?
    I hope I was clear
    rename test.zip to test.pkt
    Valued Mentor
    LeafRiders
    10-24-2012 07:52 AM in reply to: makile79
    When I go to Label Style and expressions and go new Expressions, a separate dialogue box appears to create expressions. Is there a command or way to bring up this expressions builder?
    The best reference material to SAC expressions I've found is at the tail end of Kati Mercier''s classroom handouts for her 2011 AU SAC session.
    10-25-2012 07:59 AM in reply to: makile79
    You can get a slope value from a link.  Add a link or auxiliary link between the two points that define the slope.  Assume the link is L1 - the expression would be L1.slope.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
    Employee
    10-26-2012 09:22 AM in reply to: david.zavislan
    You can also get the slope between two point P1.SlopeTo("P2") without having to add the link
    Cheers,
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
