• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    AllenJessup
    Styles Modified By and Date
    90 Views, 3 Replies
    10-28-2012 12:08 PM
    I've been modifying a template and just noticed something. If I hover over the style on the settings tab in the toolspace it gives me the information about the style including the correct Modified by and Date Modified. If I select the style the information in the lower pane is does not give me the correct information for Modified By and Date.
    I though this might be because I hadn't saved the drawing. I saved and it didn't change. So I went to a style I would have modified a couple of weeks ago. It showed the right info when I hovered over it but did not show the correct information in the lower pane.
    Is there any way to get that information to update?
    Allen
    Civil 3D 2012 sp 2.1
    Please use plain text.
    AllenJessup
    Re: Styles Modified By and Date
    10-28-2012 02:37 PM in reply to: AllenJessup
    I just notice that the problem occurs only while listing the styles one at a time. If I select the collection and display all the styles in that collection the Modified By and Date are correct. :smileysurprised:
    Allen
    AllenJessup
    10-29-2012 09:34 AM in reply to: AllenJessup
    I opened the drawing at work and see the same thing. Hover over a style and the information is correct, select the whole style set and the individual styles listed in the lower pane is correct, select a single style and the information in the lower pane is incorrect.
    I don't know where the program is getting the old information from. Why would this be stored in a different place than the rest.
    Allen
    10-29-2012 10:50 AM in reply to: AllenJessup
    When I select a single style I don't get any info at all, the whole portion is greyed out.  When I select the whole set or hover over a single style I get correct data (AFAICT).
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
