• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Style Importing
    413 Views, 5 Replies
    09-14-2012 10:15 AM
    In Civil 3D 2013 I'm attempting to import styles from another drawing.  Whenever I select the Import button under Manage > Styles I get a warning box pop up that says "The drawing has unsaved modifications.  Please save the drawings and then perform the style import again".
    This occurs even after I hit save or reopen the drawing.  Is there a fix for this issue?
    Please use plain text.
    sboon
    Re: Style Importing
    09-14-2012 10:52 AM in reply to: taketheblack
    You have to start the import command immediately after the save operation.  No pan, zoom or anything else first.
    Member
    Re: Style Importing
    09-14-2012 11:11 AM in reply to: sboon
    I'm not panning or zooming, I'm hitting save and then going straight to the import button, or even hitting the import button straight from opening the drawing.
    sboon
    Re: Style Importing
    09-14-2012 11:20 AM in reply to: taketheblack
    Search the forum - this error has been reported in the last few months.
    BrianHailey
    Re: Style Importing
    09-14-2012 12:24 PM in reply to: taketheblack
    Perhaps you have a lisp routine running that does something to your file immediately after an open or save. I know I used to have on that would modify the drawing when saved and that would probably prevent this command from running (I don't use it anymore thanks to unreconciled layers).
    New Member
    Re: Style Importing
    10-18-2012 09:28 AM in reply to: taketheblack
    I had the same problem, is your default file save format set to other than Autocad 2010?
    Mine was set to 2007 and I think that was the problem, it must run a script to make it compatible after saving which screws up the Import Settings tool.
    Try changing that and see if it works.
    James.
