• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Structures not plotting with publish
    257 Views, 4 Replies
    08-26-2010 05:32 AM
    My storm drain profiles will not plot the structures if I publish. They plot ok if I use the plot command, but I'd like to be able to publish. Has anyone run into this?
    Please use plain text.
    Active Member
    SWGDrafting
    Re: Structures not plotting with publish
    02-22-2011 01:15 PM in reply to: myerpryor
    i lose my profile when publishing my sanitary sewer profile sheets..
    Active Contributor
    01-17-2012 09:33 AM in reply to: myerpryor
    I have this problem with a few drawings also. They will plot to PDF individually using the DWG to PDF.pc3, but if i PUBLISH the existing grade in the profile is missing.
    Civil 3D 2011
    Windows 7 64bit
    12GB RAM
    11-21-2012 07:08 AM in reply to: myerpryor
    Has anyone found the reason or solution for these problems. I've been having a similar issue with my data referenced surface profile not plotting using publish.
    Now my surface profile will not appear unless I synchronize every time I open the contract drawing. I have tried recovering all drawings.
    Gerry Lacoste,
    Civil 3d 2012 sp2
    *Expert Elite*
    11-21-2012 07:51 AM in reply to: myerpryor
    Turn off publish in background and try again. This can be found in OPTIONS in the plot/publish tab.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
