• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Structure reference alignment not holding in data reference
    72 Views, 1 Replies
    11-28-2012 05:15 AM
    I have structures and alignments data referenced.  If I assign the structures ref alignments in the dwg with the data refs for labeling, the next time I open the dwg the ref alignments are set back to none, causing the labels to be ?????.
    It seems like this worked in the past?
    Thanks, Bill
    Civil 3D 2012 SP2
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Structure reference alignment not holding in data reference
    11-29-2012 08:13 AM in reply to: wvyhonsky
    It seems that references are not synchronizing. See if you can go to Manage tab and synchronize. Also in command line type REFRESHSHORTCUTNODE and see if it helps.
    Finally, once you have your labels shown see if you can set the layer where labels reside as locked. That may help, too.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
