• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Ron Mills
    Structure Profile Label Issue
    83 Views, 6 Replies
    05-19-2005 09:11 AM
    C3D 2006, Win XP Pro SP2
    I'm having a problem with the way structure labels are coming into my
    profile view.  I have one that comes in correctly, I have three others that
    don't.  They are all the same style.
    This one came in correctly.
    +[img src="@80535"]
    The Other 3 did this?  Why?  Same Lable Style entirely.
    [img src="@80542"]
    Please use plain text.
    *Matt Kolberg
    Re: Structure Profile Label Issue
    05-19-2005 01:12 PM in reply to: *Ron Mills
    Did you label the structure more than once?
    There is a bug that causes label issues when there are more than one labels
    associated with a structure or pipe.
    Matt Kolberg
    that don't.  They are all the same style.
    +[img src="@80535"]
    The Other 3 did this?  Why?  Sam e Lable Style entirely.
    [img src="@80542"]
    *Ron Mills
    05-19-2005 01:20 PM in reply to: *Ron Mills
    Only one label per structure.  Would this
    issue apply if a label was added, deleted, then
    readded?
    *Matt Kolberg
    05-19-2005 06:24 PM in reply to: *Ron Mills
    I've been able to make labels work after I delete
    all labels associated with a structure.  Then readded.
    once?  There is a bug that causes label issues when there are more than
    one labels associated with a structure or pipe.
    readded?
    *Ron Mills
    05-20-2005 04:48 AM in reply to: *Ron Mills
    For a manhole structure in profile view, what does the label use as it's
    insertion point. The insert elevation (rim) or middle of manhole?
    *Matt Kolberg
    05-20-2005 09:24 AM in reply to: *Ron Mills
    You should be able to set that under "Feature Settings" in the Pipe Network
    styles. Look for "Default profile label placement for structures" there is
    one that says "Structure label placement". However these, don't always work
    properly even if this is the first label you've applied to a structure.
    This is a known issue.
    "Ron Mills" wrote in message
    news:4851528@discussion.autodesk.com...
    *Ron Mills
    05-20-2005 10:06 AM in reply to: *Ron Mills
    "Matt Kolberg" wrote in message
    news:4851998@discussion.autodesk.com...
    That was it, problem solved. Thank you!
