• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Stringer connect rounding settings
    118 Views, 3 Replies
    09-26-2012 02:16 PM
    I have used stringer connect in the past and it seemed that my traverse shots (which went to four decimal places 0.0000) that were in my raw file were converted to a fbk file and it held the decimal places.  Now when I use it, the program rounds my shots to three decimal places (0.000) which changes the locations just slightly.  I don't think I changed any settings deliberately.  How can I get my four decimal places back?
    Thanks.
    Please use plain text.
    *Expert Elite*
    Re: Stringer connect rounding settings
    10-02-2012 08:30 AM in reply to: sparkyfeets
    Check your precision settings in the Survey database.
    On the Survey tab of Toolspace, right click the Survey database, select Edit Survey Database Settings.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    10-02-2012 09:07 AM in reply to: tcorey
    Thanks for the response.  I'm actually looking for the rounding settings for the Stringer Connect program.  I realize my question is a little out of place, this being a Civil 3D discussion group.  But I can't seem to find an answer anywhere and I know some people who frequent this discussion group also use Stringer Connect.  So I thought I'd give it a shot.
    Thanks!
    Distinguished Mentor
    10-03-2012 05:45 AM in reply to: sparkyfeets
    Which version are you using?
    I'm not sure if there is a program or part there of to set the decimal places in stringer connect.
    There is a file called numeric.dat which stores the settings used by stringer connect located either here
    C:\ProgramData\CADApps\Stringer 2011
    or
    C:\ProgramData\CSS\Stringer 2012
    or
    C:\ProgramData\CSS\Stringer 2013
    Open the file numeric.dat in notepad and change the number on the first line from 3 to 4. This is the number that controls the decimal places.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
