• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Station Labels not Annotated in Paper Space
    278 Views, 4 Replies
    03-28-2012 01:18 PM
    I am having a problem where my station labels are the correct size in model space, but when I switch to paper space they stay really small. I think it is a mm/m problem but can't seem to find a solution in the properties of the station label group. If I type a piece of mtext it works fine. Any suggestions out there? It's is driving me crazy.
    Thank You
    Please use plain text.
    neilyj
    Re: Station Labels not Annotated in Paper Space
    03-28-2012 01:24 PM in reply to: marnie.ewankiw
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/how-to-edit-station-labels/td-p/3389891
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Valued Mentor
    gjrcmb
    03-28-2012 01:30 PM in reply to: marnie.ewankiw
    Also see:
    Profile labels are not acting as ?
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Profile-labels-are-not-acting-as/m-p/3378339#M172689
    Gavin Rouleau, PE
    C3D 2012 SP1, Win XP Home
    Member
    03-28-2012 01:31 PM in reply to: neilyj
    My scales are set the same and it didn't make a difference.
    Member
    03-28-2012 01:36 PM in reply to: gjrcmb
    Thank you it was the page setup that was incorrect.
    I am not going to go crazy this afternoon.
