• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Accepted Solution
    Station Label Offest
    162 Views, 4 Replies
    11-05-2012 11:40 AM
    New to civil 3d...I have a series of bore locations along an alignment that I need the station offset and distance. I tried POINT -> ALIGNMENT: STATION/OFFSET, and that prompts me to tell where i want the offsets to go. I want to be able to pick the center of each bore and have civil 3d tell me that information. What command do I use? Help
    Please use plain text.
    *Expert Elite*
    Re: Station Label Offest
    11-05-2012 12:50 PM in reply to: southpawj05
    You should get this data just by hovering the mouse over the point.
    If that's not accurate enough or stable enough, ADD LABELS, go to Alignment Labels, Station Offset.
    I would use the Fixed Point option.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    11-05-2012 01:13 PM in reply to: southpawj05
    You're saying you don't want to label it, you want to query for the information?
    Go to the Analyze tab of the Ribbon, find the Inquiry panel and select the InquiryTool button.
    In the dialog, pick Inquiry type Alignment --> Alignment Station and Offset at Point. This will let you pick the locations of the existing points, one at a time.
    If you want a report on a group of points instead of selecting locations one-at-a-time, go to the Toolbox tab of the Toolspace, expand Reports Manager --> Points --> Station Offset to Points.
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    New Member
    11-05-2012 01:23 PM in reply to: troma
    Troma,
    That worked!!!! its exactly what I needed. Thanks for your input.
    *Expert Elite*
    11-06-2012 06:04 AM in reply to: southpawj05
    You're welcome.
    I come here to ask questions when I'm in a pickle, so I try to spread the wealth a bit while I'm here.
