AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Station Label Offest
- Highlight
- Email to a Friend
New to civil 3d...I have a series of bore locations along an alignment that I need the station offset and distance. I tried POINT -> ALIGNMENT: STATION/OFFSET, and that prompts me to tell where i want the offsets to go. I want to be able to pick the center of each bore and have civil 3d tell me that information. What command do I use? Help
Re: Station Label Offest
- Highlight
- Email to a Friend
You should get this data just by hovering the mouse over the point.
If that's not accurate enough or stable enough, ADD LABELS, go to Alignment Labels, Station Offset.
I would use the Fixed Point option.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
You're saying you don't want to label it, you want to query for the information?
Go to the Analyze tab of the Ribbon, find the Inquiry panel and select the InquiryTool button.
In the dialog, pick Inquiry type Alignment --> Alignment Station and Offset at Point. This will let you pick the locations of the existing points, one at a time.
If you want a report on a group of points instead of selecting locations one-at-a-time, go to the Toolbox tab of the Toolspace, expand Reports Manager --> Points --> Station Offset to Points.
Tim
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
Troma,
That worked!!!! its exactly what I needed. Thanks for your input.
- Highlight
- Email to a Friend
You're welcome.
I come here to ask questions when I'm in a pickle, so I try to spread the wealth a bit while I'm here.
