• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Startup problem seems to hang on "Loading AeciRibbonUiApi..."
    712 Views, 5 Replies
    01-13-2012 05:09 PM
    We seem to have a problem similar to the tool tip disappearing problem.  When we launch C3d it hangs on:
    If we hit the space bar or return, it repeats the last command (in this case toolspace) and then returns to the command prompt.  We tried unloading Raster and the problem goes away however this doesn't seem to be the best solution.
    Loaded SP1 and then the Ribbon hotfix, problem is still there.  We also stripped out all of our customizations and the problem is still there.
    Played around a bit more and found if I select the Raster ribbon tab and exit C3d, when I relaunch (which it will then start on the Raster Tab) the problem doesn't occur.......
    Any ideas for a solution.
    BTW, this is running on a Win7, 64bit OS with 64bit program versions.
    Please use plain text.
    Re: Startup problem seems to hang on "Loading AeciRibbonUiApi..."
    01-14-2012 05:12 AM in reply to: tweller
    Have you done a Repair?
    Bill
    Product Support
    Jason.Hickey
    01-17-2012 08:59 AM in reply to: wfberry
    There are random known issues with AutoCAD Raster Design interfering with the UI of Civil 3D that are scheduled for a fix. At this point, you have the workarounds - either uninstall raster design or leave the ribbon on the raster ribbon when you close the program.
    Jason Hickey
    Premium Services Specialist
    Active Member
    01-17-2012 12:29 PM in reply to: Jason.Hickey
    Not much of a solution.  FYI, we don't have this issue with 2011.
    Active Member
    04-19-2012 07:00 AM in reply to: tweller
    Jason,
    I was wondering if you folks have come up with any solution to this problem?
    Or should we continue with the workaround?
    Dave
    Win7x64
    C3D2012
    Product Support
    borycep
    08-02-2012 11:44 AM in reply to: tweller
    I am running AutoCAD Civil 3D 2012 SP1 on my desktop computer (with the Civil 3D workspace, Raster Tools included in ribbon) and when the command line seems hung up on Loading AeciRibbonUiApi, I click inside of the graphics area and the program immediately comes back.
    I did some research in our internal databases, and was not able to find information regarding if/when this issue will be fixed. For me, this has never been a real "issue", since it goes away after my first click inside of the graphics area...although maybe other users are experiencing the issue more severely?
    Phil Borycens
    Support Specialist
    AEC Infrastructure
