• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    Spot Elevation - Distance between PVI's?
    277 Views, 7 Replies
    10-22-2011 12:03 PM
    Im using Civil 3D 2012.
    I want to show the distance between Profile PVI's on a Surface Spot Elevation.
    Possible?
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Spot Elevation - Distance between PVI's?
    10-22-2011 02:06 PM in reply to: kevinjackman
    You can add profile data to alignment labels that show stations. Some finessing the style may get the desired results.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    10-23-2011 08:17 AM in reply to: kevinjackman
    I can add profile data to a spot elevation label without issue but i can't calculate the length between pvi's.
    11-01-2011 08:00 AM in reply to: kevinjackman
    Any of you label experts out there have the answer?
    *Expert Elite*
    Joe-Bouza
    11-01-2011 09:15 AM in reply to: kevinjackman
    Yes. use a featureline with a label style the shows the end elevations and distance between. Set the FL style to NoShow or NoPlot
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    11-01-2011 10:50 AM in reply to: Joe-Bouza
    Thanks Joe.
    *Expert Elite*
    Joe-Bouza
    11-01-2011 11:25 AM in reply to: kevinjackman
    HTH. Sometimes it takes a fresh look, and pulling out that stubby phillips head screwdriver the hardly gets used. :smileywink:
    I see you also got the grade in there, nice.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Joe-Bouza
    11-01-2011 11:27 AM in reply to: kevinjackman
    another way I have used is to create a FL from an alignmentent. and you can use alignment label styles to label pgl in plan
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
