• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Split drawing in half—but using Sheet Sets
    213 Views, 5 Replies
    01-25-2013 07:02 AM
    I've seen comments from others that they use a 'one sheet per drawing' policy to avoid conflicts of overlapping text in modelspace, to allow more drafters to work on a project and to cut down on file size and corruption.  We have typically had two or three sheets in a drawing, depending on the length of a street.
    For this project, when setting it up, I was considering changing our approach towards one sheet per drawing.  Then I thought to myself "Hey, no problem, I can set it up as usual and split them later if I want to."  The idea being that with everything xreffed & dreffed it's no problem to SAVEAS and delete one layout out ot this drawing and delete the other out of the other drawing.  Hey presto I'm at a one sheet per drawing situation.  But there was one thing I didn't think about: the sheet set manager.
    So now I was thinking of splitting up a drawing.  I have sheet number, title, description set up.  I have callout blocks on both sheets referencing each other and referencing other drawings, and I have callouts in other drawings referencing these sheets.
    What do you think?  Have I snookered myself?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    *Pro
    Re: Split drawing in half—but using Sheet Sets
    01-25-2013 08:19 AM in reply to: troma
    sheet manager is pretty flexible when it comes to renaming sheets.   I wouldn't worry about that.   That being said, it's probably just easier when running plan production to set it up as 1 layout per sheet.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    01-25-2013 08:39 AM in reply to: dgordon
    Not sure if I explained myself the best.
    "sheet manager is pretty flexible when it comes to renaming sheets."
    That's ok, but I don't need to rename a sheet exactly.  I will need to point the existing data within the sheet set to a different sheet, in a different drawing file.
    "it's probably just easier when running plan production to set it up as 1 layout per sheet."
    I don't follow.  What's plan production?  What am I running?  What am I setting up?  Do you mean 1 layout per drawing?  Or what am I missing?
    Thanks for the help.  I know that I'm not as deep into sheet sets as many others, so I appreciate any advice.  Currently my only idea is to delete the sheet from the set and import the new sheet.  Then I have to reenter all the data and redo the callouts in any drawing that is refferencing the sheet.
    01-25-2013 09:43 AM in reply to: troma
    Every sheet has a target dwg and target layout. I think you can edit this in the sheet set property for each sheet. No computer in front of me right now but that's where I'd check first.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    01-25-2013 09:46 AM in reply to: mathewk
    Hey, that looks promising!
    I'll let you know how it goes (if it goes).
    Thanks.
    01-28-2013 10:17 AM in reply to: mathewk
    Thanks Matt, worked like a charm!
