AutoCAD Civil 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Rogerson, Michael
Spirals >180 Deg Deflection Angle
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
122 Views, 6 Replies
11-06-2003 03:35 AM
Quick question for those of you who use (or have used) alignment spirals in
real world applications.
As you may know, Land Desktop does not allow creation of a spiral with a
total deflection angle greater than 180 degrees. There is a mathematical
reason for this.
Question - Has anyone run into any specific cases where they needed a spiral
with a total deflection angle greater than 180 degrees? If you have, some
more detail would be helpful.
Thank you,
Mike
Michael C. Rogerson, PE
Product Designer - Program Manager
ISD Civil Engineering Software Development
reason for this.
Thank you,
Mike
*wfb
Re: Spirals >180 Deg Deflection Angle
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 04:30 AM in reply to:
*Rogerson, Michael
Is this not similar to having a triangle with more than 180 degrees total in
the 3 interior angles?
"Michael Rogerson" wrote in message
news:156AE291D93BBE54FA314ED5E220ED1F@in.WebX.maYI adrTaRb...
in
| reason for this.
spiral
| Thank you,
| Mike
| Autodesk, Inc.
"Michael Rogerson"
in
| reason for this.
spiral
| Thank you,
| Mike
| Autodesk, Inc.
*Comerford, Laurie
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 05:21 AM in reply to:
*Rogerson, Michael
Hi Mike,
Bearing in mind that a driver has to assess the speed at which they can
drive around a curve and to do this they need to be able to see the curve,
it would seem fairly frightening to design a spiral through 90 degrees let
alone 180 degrees.
Laurie Comerford
CADApps
www.cadapps.com.au
"wfb" wrote in message
news:3A908D28A84BCD1D7495613993CC077B@in.WebX.maYI adrTaRb...
in
message
> in
mathematical
> | reason for this.
> spiral
some
> | Thank you,
> | Mike
> | Autodesk, Inc.
alone 180 degrees.
Laurie Comerford
CADApps
www.cadapps.com.au
"wfb"
in
> "Michael Rogerson"
message
> in
mathematical
> | reason for this.
> spiral
some
> | Thank you,
> | Mike
> | Autodesk, Inc.
*Rogerson, Michael
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 05:40 AM in reply to:
*Rogerson, Michael
Hi Laurie,
Agreed, frightening indeed! Not in roads typically but I have in pratice,
use a spiral lead-off line on a Runway/Taxiway intersection that was indeed
greater than 90 degrees, but not by much.
I'm thinking more along the lines of complex interchanges, cloverleaves,
snaking viaducts and the sort - if anyone has been held back by this
limitation.
regards,
Mike
"Laurie Comerford" wrote in message
news:37D85D08B8B752274F024B54817BCACD@in.WebX.maYI adrTaRb...
> Hi Mike,
> alone 180 degrees.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
total
> in
> message
spirals
> > in
a
> mathematical
> > | reason for this.
> > spiral
> some
> > | Thank you,
> > | Mike
> > | Autodesk, Inc.
limitation.
regards,
Mike
"Laurie Comerford"
> Hi Mike,
> alone 180 degrees.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "wfb"
total
> in
> > "Michael Rogerson"
> message
spirals
> > in
a
> mathematical
> > | reason for this.
> > spiral
> some
> > | Thank you,
> > | Mike
> > | Autodesk, Inc.
*Rizzo, Jon
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 05:46 AM in reply to:
*Rogerson, Michael
Couldn't a spiral for, say, a parking garage ramp or on/off ramp be > 180
degrees? (or the pedestrian ramps at Giants Stadium). I've often heard
these refered to as "spirals" but most likely because of their 3D shape, not
because they're spirals mathematically. I can't imagine any other time you
would use anything more than a very slight spiral. They are, after all,
just for transitions, and not the curve itself. I've only ever used
circular curves in roadway design, but that's just me. I have used spirals
in rail design, but they definately don't come close to 180 degrees.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
> Hi Mike,
> alone 180 degrees.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
total
> in
> message
spirals
> > in
a
> mathematical
> > | reason for this.
> > spiral
> some
> > | Thank you,
> > | Mike
> > | Autodesk, Inc.
Jon Rizzo
"Laurie Comerford"
> Hi Mike,
> alone 180 degrees.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "wfb"
total
> in
> > "Michael Rogerson"
> message
spirals
> > in
a
> mathematical
> > | reason for this.
> > spiral
> some
> > | Thank you,
> > | Mike
> > | Autodesk, Inc.
*Comerford, Laurie
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 06:01 AM in reply to:
*Rogerson, Michael
Hi Mike,
My experience of airports is confined to inside an aluminium tube.
However, for intersections such as you describe, I can't see any difference
in principle. A constantly changing radius on a clover leaf where you
inevitably have grade changes as well seems just as frightening.
Lastly, as wfb indicated assuming a symmetrical curve, it you have an entry
spiral > 180 degrees, add an exit spiral > 180 degrees and you have gone
through > 360 degrees. I don't think I'd approve that sort of layout. Even
with a circular curve, you would have to wonder if there is a better
solution to the intersection layout.
Laurie Comerford
CADApps
www.cadapps.com.au
news
6F1B79B06B9F5AB0FC95C4AF0C70053@in.WebX.maYIadrTaR b...
> Hi Laurie,
indeed
> limitation.
> regards,
> Mike
> > Hi Mike,
curve,
let
> > alone 180 degrees.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> total
> > in
> > message
> spirals
> > > in
with
> a
> > mathematical
> > > | reason for this.
a
> > > spiral
have,
> > some
> > > | Thank you,
> > > | Mike
> > > | Autodesk, Inc.
Laurie Comerford
CADApps
www.cadapps.com.au
"Michael Rogerson"
news
> Hi Laurie,
indeed
> limitation.
> regards,
> Mike
> "Laurie Comerford"
> > Hi Mike,
curve,
let
> > alone 180 degrees.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> > "wfb"
> total
> > in
> > > "Michael Rogerson"
> > message
> spirals
> > > in
with
> a
> > mathematical
> > > | reason for this.
a
> > > spiral
have,
> > some
> > > | Thank you,
> > > | Mike
> > > | Autodesk, Inc.
*Rogerson, Michael
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2003 11:23 PM in reply to:
*Rogerson, Michael
For the "spiral" ramp - I think, as you say, more of a "Helix" rather than
any type of 2D spiral. Would make an interesting 2D alignment indeed.
I'm certainly not expecting that anyone needs a spiral greater than 180
degrees, nor I have not ever heard of a request for one, but if there is
anyone out there that can't get something accomplished because of this, I'm
like to hear.
Mike
"Jon Rizzo" wrote in message
news:077BACE3E38C2B97B20238C5DED07020@in.WebX.maYI adrTaRb...
not
you
spirals
> Jon Rizzo
> > Hi Mike,
curve,
let
> > alone 180 degrees.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> total
> > in
> > message
> spirals
> > > in
with
> a
> > mathematical
> > > | reason for this.
a
> > > spiral
have,
> > some
> > > | Thank you,
> > > | Mike
> > > | Autodesk, Inc.
like to hear.
Mike
"Jon Rizzo"
not
you
spirals
> Jon Rizzo
> "Laurie Comerford"
> > Hi Mike,
curve,
let
> > alone 180 degrees.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> > "wfb"
> total
> > in
> > > "Michael Rogerson"
> > message
> spirals
> > > in
with
> a
> > mathematical
> > > | reason for this.
a
> > > spiral
have,
> > some
> > > | Thank you,
> > > | Mike
> > > | Autodesk, Inc.
