• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    yazzie91
    Some Desc Keys wont work
    155 Views, 4 Replies
    12-20-2011 09:13 AM
    I am drawing up a topo survey and some of my DescKeys wont work. Most of them work, but some just dont. My J-BOX, PWR RISER and gate post. Attached is an image of my desckey and point. Am I doing something wrong?
    Please use plain text.
    Re: Some Desc Keys wont work
    12-20-2011 11:59 AM in reply to: yazzie91
    Get rid of all spaces in your raw descriptors and keys.  Replace them with underscores or dashes.
    Standardize on all CAPS too.
    Valued Mentor
    12-20-2011 12:14 PM in reply to: yazzie91
    You might also look for any conflicts in your DescKeys with wildcards - say if you have a key as J* or P* those would be used first and J-BOX and PWR RISER would be ignored.
    Double-checked the Point File as well to make sure it's using the right field codes.
    HTH
    AWood
    yazzie91
    12-20-2011 12:27 PM in reply to: yazzie91
    Thanks! Using the under score worked. So dashes, spaces and lower case point descriptions wont work with the desckeys?
    Valued Mentor
    IanMcClain
    12-20-2011 01:53 PM in reply to: yazzie91
    The description key uses space as a delimiter between fields, there is no option to change that. Anything else is seen as a part of the description/field.
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
