AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Smooth Road Profiles created from Lidar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have lucky enough to obtain LIDAR for most of our small City as well as ground only points. My problem is that profiles produced using it are rough and jagged (see attached). I've tried contour smoothing to no avail as well as point removal. Perhaps I haven't just tried enough options.
Should mention also I have breaklines along the CL alignment as well as Edge of Pavement.
Any ideas?
Re: Smooth Road Profiles created from Lidar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With Lidar you're pretty much stuck. There's really too much data and without proper breaklines it doesn't triangulate along the road crown as it should. We have had some success at creating a "fake" ground profile by drawing a featureline to trace the centerline where it's visible in the photo. You can either snap the featureline points to the Lidar nodes or use the Elevations from Surface command, then project the featureline onto your profile view.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Judging the contours in the plan view it appears the LIDAR surface has issues. The contours in the paved areas should not be meandering like that. I'd run some checks on the surface and source data.
Do you receive breakline data with the LIDAR dataset?
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No we didn't but I have 2d polylines as breaklines in the drawing at the edge of pavement and the centerline.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Like Steve, I would look at using the lidar data to recreate the Roadway. Either with FL's or a layout profile and simple corridor to extract the FL's for CL and EOP.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What would a normal preliminary survey be in your area? We usually see surveys with a cross section every 25m and for each feature of the road. At the most this is what I'd have to define my EG in this instance. Clearly the LIDAR data is overkill for road design.
Maybe you could try to insert a point along each of the breaklines at common interval and redefine your EG surface to be something like EG_reduced. Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks to all that replied, for now I think the idea of placing a point on the Lidar Surface every 25m would be a great idea combined with a 3D poly breakline.
I have always had problems with jagged profiles and a 3D poly breakline has always solved them.
