• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    Smooth Road Profiles created from Lidar
    483 Views, 6 Replies
    08-14-2012 12:02 PM
    We have lucky enough to obtain LIDAR for most of our small City as well as ground only points.  My problem is that profiles produced using it are rough and jagged (see attached).  I've tried contour smoothing to no avail as well as point removal.  Perhaps I haven't just tried enough options.
    Should mention also I have breaklines along the CL alignment as well as Edge of Pavement.
    Any ideas?
    Please use plain text.
    *Expert Elite*
    sboon
    Re: Smooth Road Profiles created from Lidar
    08-14-2012 12:52 PM in reply to: robert.thomson
    With Lidar you're pretty much stuck.  There's really too much data and without proper breaklines it doesn't triangulate along the road crown as it should.  We have had some success at creating a "fake" ground profile by drawing a featureline to trace the centerline where it's visible in the photo.  You can either snap the featureline points to the Lidar nodes or use the Elevations from Surface command, then project the featureline onto your profile view.
    *Expert Elite*
    Neilw
    08-14-2012 12:54 PM in reply to: robert.thomson
    Judging the contours in the plan view it appears the LIDAR surface has issues. The contours in the paved areas should not be meandering like that. I'd run some checks on the surface and source data.
    Do you receive breakline data with the LIDAR dataset?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    08-15-2012 05:02 AM in reply to: Neilw
    No we didn't but I have 2d polylines as breaklines in the drawing at the edge of pavement and the centerline.
    *Expert Elite*
    johnm
    08-15-2012 06:05 AM in reply to: robert.thomson
    Like Steve, I would look at using the lidar data to recreate the Roadway. Either with FL's or a layout profile and simple corridor to extract the FL's for CL and EOP.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Valued Mentor
    LeafRiders
    08-15-2012 01:00 PM in reply to: johnm
    What would a normal preliminary survey be in your area? We usually see surveys with a cross section every 25m and for each feature of the road. At the most this is what I'd have to define my EG in this instance. Clearly the LIDAR data is overkill for road design.
    Maybe you could try to insert a point along each of the breaklines at common interval and redefine your EG surface to be something like EG_reduced. Good Luck.
    08-17-2012 04:20 AM in reply to: LeafRiders
    Thanks to all that replied, for now I think the idea of placing a point on the Lidar Surface every 25m would be a great idea combined with a 3D poly breakline.
    I have always had problems with jagged profiles and a 3D poly breakline has always solved them.
