AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Small Vertical Curves label options...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
New here to the forums. I have a question. I have a profile that has a 25' VC (please see attached jpeg) and want to put my PVI Station and Elevation but it doesnt fit in 40 scale (I need it to be in 40 scale). Is there a way I can only change the style for small vertical curves without changing my other styles? Thanks.
Juan
Re: Small Vertical Curves label options...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can certainly create a new label style, then Ctrl+click on this label and switch it to the new style in the properties box.
I don't know if you can set it up to automatically switch styles based on the length of the curve. One option may be to have text x and y offsets based on expressions that give a different value based on the cuve length, but I'm not sure if it's possible.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Don't know of a way without changing style as troma suggests but here's an example of having the vc text appear above the label which may clean it up some. This is how we have ours set up and there's no interference with the lines & horizontal text overlap.
C3D 2012 SP3
Win 7 Professional 64 Bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is one of our default profile label sets. Most of the VC info is moved to the top & bottom of the grid, so that it doesn't interfere with the profile linework.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks guys. I ended up creating a new style for 25' VC or smaller and also a 50' VC. Here in California, all agencies require to show the dimension lines and PVI info. I cant just call a PVI Station and Elevation without Dim lines. Heres what it looks like now. (See attached)
Thanks for all your help again ![]()
