• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Roadapple
    Accepted Solution
    Slope Stake Report Issues
    170 Views, 2 Replies
    11-18-2012 01:49 PM
    When trying to create a Slope Stake Report a window pops up and states "No corridors in Hwy Design.dwg".
    The drawing is called Hwy Design.  And there are corridors in it.  I can select them and edit them and everything.  I just can't create a slope stake report.
    I should also mention that for some unknown reason I have a corridor that is no longer there.  I don't know if I accidentally deleted it, but it is not there. The alignment was gone.  The profile was gone.  The cross sections and even the mass haul diagram.  All gone.
    - I am new to civil 3d and had everything in one drawing.   And yes, I will never do that again!
    But even after re-creating the alignment and the corridor and cross sections, it still gives me the message that there are no corridors in the drawing.
    Any help would be appreciated.
    Please use plain text.
    *Expert Elite*
    Re: Slope Stake Report Issues
    11-19-2012 01:06 PM in reply to: Roadapple
    Post your drawing and someone here will take a look...
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Roadapple
    11-20-2012 09:10 AM in reply to: tcorey
    Thanks but problem solved.
    I had an older version of the drawing and all I did was copy the alignment from it to the newer version.  I associated the corridor with it and was able to generate slope stake notes.  I had to recreate the sample lines to get cross sections and recreate the profile view.  But it is working.
