• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Slope Analysis Help
    74 Views, 5 Replies
    05-17-2005 01:51 PM
    I am running Civil3D 2006 and I am trying to slope analysis the surface. I want a color and are for like 0-12.5%, 12.5-25% and 25%+. I do not see how to define this. Any help would be great. Thank You.
    Please use plain text.
    *Ron Mills
    Re: Slope Analysis Help
    05-18-2005 06:53 AM in reply to: gnewland
    wrote in message news:4848136@discussion.autodesk.com...
    Surface Properties>Analysis Tab> see if that will get you started. In your
    situation you'll need to set it for (3) regions.
    05-18-2005 07:18 AM in reply to: gnewland
    Very Helpfull, thank you.
    05-18-2005 08:02 AM in reply to: gnewland
    Now one more question. How do I calculate the area of each slope region I have? Is this Possible?
    *Ron Mills
    05-18-2005 08:24 AM in reply to: gnewland
    Next go to Column Value.. Double click on the empty colum value
    wrote in message news:4849013@discussion.autodesk.com...
    Import the associated table
    Under Surfaces>Add Legend Table>
    Then pick your surface, choose slope as the legend table. Insert it into
    drawing. It won't immediately have the surface area of each section
    showing. You'll have to edit the table style.
    So.. select the table, right click, edit table style...
    On the bottom, you'll see grid display. On the left of the window, you'll
    see a plus, click it. An empty grey box will appear on the grid next to
    "color". double click that grey box and type in "AREA"
    Next go to column width.. it should be "automatic"
    From the drop down list, choose either surface range 2d or 3d area click the
    little blue area to populate the field
    close outo of all.
    Regen surface and your table should update with the surface areas.
    05-18-2005 10:56 AM in reply to: gnewland
    Once again you hit the nail on the head. Thanks
