AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Single Errant Corridor Section in Cul De Sac
- Highlight
- Email to a Friend
- Report Inappropriate Content
See the attached image. I have a single corridor "section" that extends from the 'tip' of my cul-de-sac back to the start of the alignment. Any thoughts on what is causing this?
I scoured the group before posting and didn't see anything quite the same.
Would it have something to do with the corridor line being parallel to the alignment?
Thanks.
Re: Single Errant Corridor Section in Cul De Sac
- Highlight
- Email to a Friend
More than likely. Can you delete the offending corridor section? Another option may be to edit the centerline alignment to add a very small circular segment at the center of the culdesac, so that the corridor can target it properly.
- Highlight
- Email to a Friend
I ended up splitting the baseline into two regions to solve this. I created two regions with a 0.1' gap to avoid the point where the alignment was parallel to the offending corridor section. It 'worked' but might not be the preferred solution.
