• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    sadekcivil
    Re: Side Slope Overlapping Issue
    11-26-2012 01:20 AM in reply to: ericcollins6932
    Can you explain in stepses.
    Thank you for your advice
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
    Please use plain text.
    Valued Mentor
    fcernst
    11-30-2012 06:11 AM in reply to: sadekcivil
    Omit the crossing daylight links through your Section parameter editor.  See the two pictures below.
    This stinks that Civil 3D does not have the intelligence to clean up intersecting Daylighting in Corridors. Especially, when using two Baselines in the same Corridor!
    22
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    *Expert Elite*
    neilyj
    11-30-2012 06:17 AM in reply to: fcernst
    The Autodesk BIM dream is still a long way off in Civil 3D I'd say...
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    sadekcivil
    12-31-2012 09:55 AM in reply to: sadekcivil
    I figure out the best way to do that,
    1- Create surface from Baseline 1
    2- Create a fetureline form the surface of Baseline 1 that located in the intersection between corridor 1 & 2
    3- Create subassembly that target featureline by using linkoffsetandelevation
    Any queries will be wellcom
    Valued Mentor
    fcernst
    01-03-2013 04:14 PM in reply to: sadekcivil
    I take back my "C3D stinks" on this grading cleanup issue with Corridors. SAC is making me me eat those words.
    I created a subassembly in SAC that cleans up intersecting daylight links between two Corridors. You can see below, between two crowned corridors, the daylighting links catch into existing ground, and stay apart up to about Sta 0+70. The corridor on the left is daylighting at 25%, and the corridor on the right is daylighting at 15%.
    After that,  they are intersecting and cleaning up with each other.
    Ernst Engineering
    Fred Ernst, PE
    sadekcivil
    01-04-2013 11:44 AM in reply to: fcernst
    Dear Mr.Ernst,
    I will be appreciate if you can send me the .pkt file so that it will help me to reduce a time to produce that corridor.
    Thank you.
    Sadek
    sadekcivil
    01-17-2013 07:30 AM in reply to: fcernst
    Dear Mr.Ernst,
    Can you explain how you did your template in SAC or can you post your .pkt file here please.
    For your advice please.
    Thank you.
    Sadek
