• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Sharing Surfaces in 2006
    43 Views, 3 Replies
    04-13-2005 06:59 AM
    With the use of the new data shortcuts, can I reference a surface, and then add hide boundaries to the surface reference without adding them to the actual surface object? What we need is the ability to show an existing surface on one sheet, and then show the surface with contour lines hidden across roads or grading pads on another. If this capability does not exist, is there a way now (or in '06) that we can do this without having two different files with two different surfaces? Thanks.
    Please use plain text.
    *James Wedding, P.E.
    Re: Sharing Surfaces in 2006
    04-13-2005 07:22 AM in reply to: kevincurrey
    You cannot do this with references, since references are locked. You
    could use the project setup to checkout the surface from the project,
    then apply your boundary.
    I haven't tried it, but it should work. You might lose the boundaries
    when you update from the project. An interesting conundrum.
    James Wedding, P.E.
    Technology Manager &
    Associate
    Jones & Boyd, Inc.
    Dallas, TX
    XP/2 on P4-3.4/1G
    LDT2005SP1 & C3D2005SP1
    *Brian Hailey
    04-13-2005 10:04 AM in reply to: kevincurrey
    Hi Kevin,
    I've experimented using wipeouts to simply hide the contours I don't want
    shown but haven't actually used it for production yet.
    Brian Hailey
    LDT2005
    C3D2005
    XP Pro - SP 2
    P4 2.8GHz
    1.00 GB of RAM
    wrote in message news:4813336@discussion.autodesk.com...
    *Jon Rizzo
    04-14-2005 06:35 AM in reply to: kevincurrey
    If anything, this is a very temporary workaround. I mean, what happens when
    you want to modify the original surface in both drawings? If you update the
    modified surface back to your project, both copies will have the new
    boundaries. I think what would be needed here is a "child" object.
    Surface1 + boundaries = Surface2. I think this could be quite useful if we
    could have one "master" surface, and then several children which are just
    variations of the surface. A good example would be a large subdivision done
    in phases. We might have several thousand acres of topo, but only need a
    fraction of it for phase 1, and subsequent phases may have boundaries that
    overlap phase 1.
    I think the project mechanism is a major weak point in the product right
    now. There are TWO separate data sharing mechanisms, and neither one is
    complete or ideal. It would have been better if they could have just added
    alignments and profiles to the original project mechanism and skipped
    shortcuts all together. They take WAY too long to validate whenever you
    open any drawing in a project, and they don't really offer anything that
    wasn't already available. In addition, dragging multiple copies of existing
    ground surfaces around is going to kill our data drive, but that is a
    problem with either mechanism.
    Jon Rizzo
    Langan Engineering and Environmental Services, Inc.
    ; "P.E." wrote in message
    news:4813391@discussion.autodesk.com...
    > James Wedding, P.E.
    > Associate
    > Jones & Boyd, Inc.
    > Dallas, TX
    > XP/2 on P4-3.4/1G
