• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    manmonza
    Accepted Solution
    Shapefile
    179 Views, 6 Replies
    02-08-2013 12:34 PM
    Hello everybody, i have a question about exporting a 2d drawing to a Shapefile. I have checked out the Help file supplied with AutoCAD Civil #D 2013, but for the life of me I can not figure it out. Would anybody be able to help me?
    Please use plain text.
    *Expert Elite*
    Re: Shapefile
    02-08-2013 12:45 PM in reply to: manmonza
    command is _MAPEXPORT (>>>details<<<) .... and then let us know, if something does not work in the way you need.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    manmonza
    Re: Shapefile
    02-08-2013 01:01 PM in reply to: alfred.neswadba
    Thank you for the quick reply. I will let you know how it works out for me.
    *Expert Elite*
    antoniovinci
    Re: Shapefile
    02-08-2013 01:42 PM in reply to: manmonza
    Be aware, that you won't export an entire drawing to shape format, sir.
    Depending on objects you choose, the _MAPEXPORT will filter either:
    1. points
    2. lines
    3. polygons
    4. texts
    so you'll get up to 4 different shapesets.
    *Expert Elite*
    Murph
    Re: Shapefile
    02-08-2013 03:16 PM in reply to: antoniovinci
    1. points
    2. lines
    3. polygons
    4. texts
    Depends on what is all in the dwg, using mulitclass shape it will export most AutoCAD objects and create mulitlpe files.
    Murph
    Supportting the troops daily.
    Valued Contributor
    bcinnv
    Re: Shapefile
    02-10-2013 01:25 AM in reply to: Murph
    Assuming you are talking about GIS applications mapexport works fine. Be sure to set your drawing to a coordinate system, and that you are on one.
    If you are speaking of other applications, such as for linetypes, please use the express tools->tools->make shape
    - Brian
    "Very funny, Scotty. Now beam down my clothes."
    manmonza
    Re: Shapefile
    02-12-2013 12:46 PM in reply to: manmonza
    What you stated to do worked just fine for what I needed to do. Thanks for your help.
