• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    Setting up custom coordinate system for COGO points
    342 Views, 4 Replies
    07-10-2012 06:44 AM
    Hi!
    I have a small field (5 by 5 meters) to be set out with about 40 points. Currently i use EOV (Hungarian National Coordinate System), thus each point has a lot of digits. I want to make the implemetor's job easier, so i want to move and rotate the CS near to my field.
    I tried to use UCS, but the COGO points retained the "World" coordinates.
    Do you have any idea how to carry out this without moving my whole drawing to the origin?
    Thanks!
    Please use plain text.
    *Expert Elite*
    Re: Setting up custom coordinate system for COGO points
    07-10-2012 09:50 AM in reply to: david.mustyak
    You can truncate the coordinates.
    http://www.civil4d.com/2008/01/truncs-arent-just-for-elephants/
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Member
    07-10-2012 10:53 AM in reply to: mathewk
    Thanks, Matt!
    It is a perfect solution for truncating the digits, but i would like to rotate the CS as well, as it is shown below.
    I think it can be solved with trigonometric functions, but isn't there an easier way?
    Distinguished Contributor
    07-10-2012 11:35 AM in reply to: david.mustyak
    I think this is a perfect example of a use for the "Transformation" tab found in Drawing -> settings.
    We don't really want to MOVE or ROTATE the points, we just want to change the display of the points.
    I would look into the Transformation tab, and then revise some of the labels to use the "grid" coordinates, instead of the "local" coordinates.
    __________
    Craig T. Bailey, PE
    Civil Engineering Consultant
    Member
    07-10-2012 12:06 PM in reply to: ctbailey
    I tried to use the Transformation before but i didn' know about the grid coordinates.
    Now it works perfectly! Thanks!
