• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Serious Reactor Error
    265 Views, 7 Replies
    02-01-2012 12:42 PM
    Has anyone ever seen "Serious Reactor Error" (see attached)?
    I was trying the EXPORTOAUTOCAD command when the error popped up. It was not a huge deal. I exited out of the drawing,  reopened it and it worked fine.
    It's just something I had never seen before
    I wonder if I should find a bomb shelter somewhere . . .
    Please use plain text.
    Product Support
    machadt
    Re: Serious Reactor Error
    02-02-2012 04:34 PM in reply to: andram-teco
    Hi Andra,
    Do you Have any custom routines loaded on your Civil 3D?
    Tatiana Machado
    Americas AEC Infrastructure Product Support Specialist
    02-03-2012 09:56 AM in reply to: machadt
    Hi Tatiana,
    Just one: MdiTab18.arx
    Thanks!
    Product Support
    machadt
    02-03-2012 10:57 AM in reply to: andram-teco
    If don’t mind me asking, what this routine does??...
    The routine is the one causing the error message, it is conflicting with another portion of the software…
    Tatiana Machado
    Valued Mentor
    MarySeufert
    02-06-2012 10:05 AM in reply to: machadt
    See this Shaan Hurley blog... Drawing Tabs
    ~ Mary
    ___________________________________________________________________
    Normal people believe that if it ain't broke, don't fix it.
    Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
    Product Support
    machadt
    02-06-2012 10:32 AM in reply to: MarySeufert
    Thanks for the link Mary,
    If that is the tool that you are using, it was create it to be use on ACAD 2010, with that been said some times this type of tools could work on newer versions but it looks like something is conflicting with 2012, that is a programming error.
    Tatiana Machado
    02-06-2012 01:20 PM in reply to: machadt
    Thanks Mary & Tatiana,
    If I run into the error again, I'll remove the tool. Don't want to suffer from any fallout after all.
    Valued Mentor
    MarySeufert
    02-06-2012 02:02 PM in reply to: andram-teco
    If you need a replacement for MDITabs, I use this Drawing Tabs by CAE-Link, which is compatible with 2007-2012 and free! I haven't run into any issues so far on any of my ACAD versions.
    ~ Mary
