AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Send LAYER to back in display order. Not entities, the entire layer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Any advice on how to send an entire layer to the back in display order, not just entities?
Civil 3D 2008
Re: Send LAYER to back in display order. Not entities, the entire layer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you have to make a selection set. qselect all enties by layer
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks! I will give that a shot.
Honestly, I am kind of astonished that there's not an easier way to control layer orders.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD has never used that sort of system to control draw order. Instead, it allows us to control draw order by individual objects. This gives us more flexibility, but it can be argued that it gives us TOO MUCH flexibility, and controlling draw order on a per-layer basis would work better in many situations.
Given how many years AutoCAD has been the way it is, however, I wouldn't hold my breath on seeing this change any time soon...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Incidentally, there is a tool on Autodesk Labs that will do this.
Cansel - Autodesk Division
http://www.cansel.ca/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know this is an old thread, but Im having trouble loading the dll file. This is what I get when I use the NETLOAD command:
Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' or one of its dependencies. Operation
is not supported. (Exception from HRESULT: 0x80131515)
File name: 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework.
This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
at System.Reflection.RuntimeAssembly._nLoad(AssemblyN
at System.Reflection.RuntimeAssembly.InternalLoadAsse
assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadFrom
Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
StackCrawlMark& stackMark)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(Stri
at loadmgd()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It was created a while ago. it's probably not compatible with your version of AutoCAD. In the link it says it was tested on 2007, which likely would make it not work for 2010 and above.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check out Lee Mac's lisp for this
http://lee-mac.com/layerdraworder.html
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
