• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Send LAYER to back in display order. Not entities, the entire layer
    1476 Views, 7 Replies
    05-06-2011 08:03 AM
    Any advice on how to send an entire layer to the back in display order, not just entities?
    Civil 3D 2008
    Please use plain text.
    Joe-Bouza
    Re: Send LAYER to back in display order. Not entities, the entire layer
    05-06-2011 08:19 AM in reply to: dbinkney
    you have to make a selection set. qselect all enties by layer
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    05-06-2011 08:24 AM in reply to: Joe-Bouza
    Thanks! I will give that a shot.
    Honestly, I am kind of astonished that there's not an easier way to control layer orders.
    05-06-2011 08:29 AM in reply to: dbinkney
    AutoCAD has never used that sort of system to control draw order.  Instead, it allows us to control draw order by individual objects.  This gives us more flexibility, but it can be argued that it gives us TOO MUCH flexibility, and controlling draw order on a per-layer basis would work better in many situations.
    Given how many years AutoCAD has been the way it is, however, I wouldn't hold my breath on seeing this change any time soon...
    Sinc
    05-06-2011 11:09 AM in reply to: dbinkney
    Incidentally, there is a tool on Autodesk Labs that will do this.
    http://labs.blogs.com/its_alive_in_the_lab/2011/01/january-adn-plugin-of-the-month-draw-order-by-lay...
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Member
    ITTCowboy
    02-15-2013 12:45 PM in reply to: dbinkney
    I know this is an old thread, but Im having trouble loading the dll file. This is what I get when I use the NETLOAD command:
    Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' or one of its dependencies. Operation
    is not supported. (Exception from HRESULT: 0x80131515)
    File name: 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework.
    This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
       at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
       at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName
    assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
       at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile,
    Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
    hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
    StackCrawlMark& stackMark)
       at System.Reflection.Assembly.LoadFrom(String assemblyFile)
       at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
       at loadmgd()
    02-15-2013 01:00 PM in reply to: ITTCowboy
    It was created a while ago.  it's probably not compatible with your version of AutoCAD.  In the link it says it was tested on 2007, which likely would make it not work for 2010 and above.
    Matt Kolberg
    02-15-2013 01:19 PM in reply to: ITTCowboy
    Check out Lee Mac's lisp for this
    http://lee-mac.com/layerdraworder.html
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
