• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    Selection within the same layer
    127 Views, 3 Replies
    01-25-2013 12:14 AM
    Hi!
    If I have one layer containing different kinds of objects in different colour, is there any way I can select all those of one color? For example, I have houses in magenta and roads in white but in the same layer. If I mark a house and use Select Similar the entire layer will get selected although I just want to select the houses. Can I do a selection based on the colour they have?
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Selection within the same layer
    01-25-2013 12:17 AM in reply to: Tomosara
    Try using the Quick Select method (should be on right click)
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    01-25-2013 12:31 AM in reply to: neilyj
    That totally did it =) Thanks!
    *Expert Elite*
    neilyj
    01-25-2013 12:47 AM in reply to: Tomosara
    Excellent :smileyhappy:
    Can you mark the post as a solution as an aid to others in the future (and Kudos is gratefully acccepted as well..!!!)
    neilyj
