• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Valued Contributor
    csevers
    Selection Box
    144 Views, 4 Replies
    01-06-2013 03:24 PM
    How can I disable the selection dialog box and enable selection cycling? I used to be able to hit shift+space bar to cycle through overlapping lines, I'd like to still be able to do that. I just switched from C3D 2011 to 2012.
    Please use plain text.
    Valued Contributor
    csevers
    Re: Selection Box
    01-06-2013 03:31 PM in reply to: csevers
    This may or may not be related, but when I'm in paper space my osnaps are going crazy, I'd also like to disable whatever is causing this. See attached screen cap (taken in PS).
    *Expert Elite*
    Re: Selection Box
    01-06-2013 04:01 PM in reply to: csevers
    It looks like you are over the area blocked out by a clipped viewport. Autocad still sees those objects as if the normal rectangular viewport was in use. SHould it be like this? No, IMHO, but that's the way it currently works.
    Jeff_M, also a frequent Swamper
    Valued Contributor
    Re: Selection Box
    01-07-2013 06:09 AM in reply to: csevers
    Disabling Selection Cycling should be as easy as hitting Ctrl+W it will toggle it off/on as needed.  Or hit the icon at the bottom of your screen (Furthest to the right looks like a crosshair with 2 boxes on top of each other).  For Selection Cycling it will be a little more work, I THINK you can get what you want by setting "SELECTIONPREVIEW" to 3 and "SELECTIONCYCLING" to -2.  of course you enter both those variables without the " ".  Good luck..
    *Expert Elite*
    Re: Selection Box
    01-07-2013 08:51 AM in reply to: csevers
    You can still hit Shift+Spacebar if that's what you want. Use Shift+Spacebar to put AutoCAD in selection cycling mode, and then click the left mouse button until the object you want selected is highlighted.
    The new selection cycling is an awesome tool, but it can really slow down the movement of your crosshairs so it's not a bad idea to leave it off until you need it or use Shift+Spacebar instead.
    Best regards,
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
