• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    Selecting Civil3D objects
    197 Views, 3 Replies
    02-04-2013 12:29 PM
    I’m using Civil3D 2012 and I have an issue that is driving me crazy. When I select any Civil3D obect (alignment, profile view, feature line, etc.) the crosshairs turn into my default Windows Pointer and the Civil3D window is inactive. I either have to click in the window to reactivate it, or hover my pointer over the Toolspace, then the crosshairs reappear. I haven’t had this problem in any previous version of Civil3D and it’s really bugging me. If anyone knows how to fix this I'd really appreciate it.
    Please use plain text.
    *Expert Elite*
    Adriano_cad
    Re: Selecting Civil3D objects
    02-04-2013 12:45 PM in reply to: kentkeuhn8519
    HI,
    You need to check your video settings in the options of AutoCAD Civil 3D.
    Check Manual Performance Tuning Dialog Box
    Adriano Oliveira
    *Expert Elite*
    MaxiCAD Informática
    www.maxicad.com.br
    Member
    02-04-2013 12:57 PM in reply to: Adriano_cad
    Thanks for the quick reply, but that wasn't it. My settings were exactly as those in your attachment. I don't suppose you have any other ideas?
    Member
    02-06-2013 01:08 PM in reply to: kentkeuhn8519
    I finally figured out that it has to do with Quick Properties being enabled. This is a known problem in C3D 2012 and 2013. There is no planned fix until the release of C3D 2014. Thanks for doing nothing, Autodesk!
    Here is a previous thread I found about this issue:
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/2013-Quick-Properties-and-extra-clicks/td-p/3537878/h...
