• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    Select Object
    159 Views, 3 Replies
    10-18-2012 02:18 PM
    Spoiler
    Is there a way to select a xref by the name?
    I would like to use it in a script along with Draworder, moving the xref to the back.
    But this option is not in the list:
    Select Object: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
    revious/Undo/AUto/SIngle/SUbobject/Object.
    Please use plain text.
    *Expert Elite*
    Re: Select Object
    10-18-2012 04:19 PM in reply to: akbarg
    You can use a line of lisp to do it for you:
    (ssget "x" '((2 . "*Parcel*")))
    Replace "*Parcel*" with the name of the xref you want to select. Or use wildcards as I did...what I show will select all Inserted blocks (which includes Xrefs) whose name includes Parcel. It is not case-sensitive.
    Re: Select Object
    10-19-2012 05:05 AM in reply to: Jeff_M
    Thanks!
    It did the job!
    Have a nice day!
    Re: Select Object
    10-19-2012 05:10 AM in reply to: Jeff_M
    This choice should be included in SELECT command!
