• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Section Hatch
    205 Views, 5 Replies
    09-27-2012 01:08 PM
    I have searched the Help fine in Civil 3D, I have searched the tutorials and Knowledge Base online, I have searched the Mastering AutoCAD Civil 3D manual, and I can not fine how to turn on hatching in Section Views. Can anyone shed some light on this subject? I'm currently running Civil 3D 2013.
    Randy A. Owens
    Southland Engineering, Inc.
    Win 7 64BIT
    C3D 2013
    Please use plain text.
    Re: Section Hatch
    09-27-2012 01:47 PM in reply to: randyowens3203
    The onlt hatching that happens in section views is from shapes. You'll need to have a shape sampled such as asphalt or base material. After that, it's just a matter of configuring the shape style properly; don't forget to have the "Section" view direction toggled in the Display tab of that style.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Valued Contributor
    Re: Section Hatch
    09-27-2012 01:54 PM in reply to: mathewk
    I have set up the Materials List & Quantity Takeoff Criteria, and have run volume reports. I just can't fine how to get to the shape/hatching part of it. There appears to be little documentation about this, at least I have not found it, yet.
    Randy A. Owens
    Win 7 64BIT
    C3D 2013
    Re: Section Hatch
    09-27-2012 02:05 PM in reply to: randyowens3203
    Attach the file if it's small enough or make it smaller somehow.
    Matt Kolberg
    Valued Mentor
    LisaPohlmeyer
    Re: Section Hatch
    10-01-2012 08:20 AM in reply to: randyowens3203
    If you want hatching like the attached pic, it's done through the Code Set Styles
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Valued Contributor
    Re: Section Hatch
    10-01-2012 08:26 AM in reply to: LisaPohlmeyer
    I'm actually referring to the hatching based on volume reports, that hatches the cut and fill areas.
    Randy A. Owens
    Win 7 64BIT
    C3D 2013
