AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Screen flickers when moving the mouse around an open drawing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay,
As the title says,
The screen flickers when I move the mouse around an open drawing. I just applied the latest patch to Civil 3D 2010. It was not doing this before the patch.
Have Quadro 3500 video card. Updated the driver for that with no change.
Have a Logitech wireless mouse, M310. Up dated the driver for that with effect.
Changed to a wired mouse, no change.
Is there a setting in Autocad where I can set the refresh rate so that it does not refresh while moving the mouse. Or at least slow the automatic refresh rate down?
Re: Screen flickers when moving the mouse around an open drawing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Don't be discouraged, it is unlikely that you would have figured it out, fortunately for me and others someone determined the fix.
Turn off Hardware Accelleration, then turn it back on.
(Don't ask why, just accept it.)
<G>
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Land Consultants
Civil3D 2012 (Service Pack 2.1)
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That works. Thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That worked. Thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just wanted to point out that there are a number of other symptoms that we have found related to this issue. Most likely it is being caused by an unsupported graphics card driver, or unsupported graphics card. Development is looking into why Update 1 might have triggered this issue for many users.
As noted in previous suggestions, the resolution for this issue is to toggle the Hardware Acceleration option.
Please refer to the following technical solution for a complete list of the symptoms and a complete list of steps to resolve these issues: http://usa.autodesk.com/getdoc/id=TS15851876
Joshua Coombs
Global Technical Lead – AEC Civil
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi there, I used an Applle Display for Revit, and i was having the same problem; each time i click anywhere, the windows started flickering or flashing.... I've deselected the "press &Drag" case but didnt resolve.... After making uptades and trying to fix it, nothing
work. Finally after 5 hrs waisting my time, I fixed by the dummiest way i imagine:
Under the ribbon, there is a line that actiates when you select a title block or something, right click and select "Dock at Bottom".... anyways that solve my problem.
