Save window not showing up
TTamburri
TTamburri
So when ever I save something I get the file path and information coming up in the command bar but I am no longer getting the extra window showing up on the screen. I was wondering if anyone has come across this before and if you now how to fix it?
Replies (46)
SethHall
Hi tbyrne-
Try FILEDIA and setting it to <1>. This should allow your save dialog to display again.
Hope this helps!
Seth Hall
Product Owner
Model Builder
TTamburri
Thanks so much.
Yea, just had the same thing here on 2011, and also some day ago on 2010. Why does it happen anyway I didn't touch a thing 😛
If you are using lisp routines, you might have one that sets filedia off and doesn't restore it if the routine fails for some reason.
very very thanx
It Worked. Great!!!
Thank you!!!
fguzma4
Community Visitor
Community Visitor
Thanks, it works. I am using autocad Electrical 2015. Thanks so much!
My FILEDIA setting is already set to <1> and is still not showing the save window after pressing <OK> in plot window. What other possible solutions might there be? I am using AutoCAD Plant 3D 2017.
thanks folks!
thank you so much i fixed it
Thank you
Thank you so much ! i had the same problem and it worked.
genius !!! well done
Mine just did the same thing... Fix worked great!  Thanks!
Yes it worked for me
thanks a lotWoman Very Happy
thanks a lotttttttttttttttttttttttt
RAGHUVEER814ZDVTC
Observer
Observer
Thanks a lot
