• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    LeafRiders
    Sample Line Stationing Text Not updating
    89 Views, 2 Replies
    01-14-2013 12:36 PM
    I have some sample lines that highlight utilities needing a section view. I've now moved my sample line to highlight the true cross section stationing for these crossings. Why doesn't the station value update for the sample line once this is moved. For some reason I remember the station text on the sample line updating itself automatically in the past. I search this forum and nothing came up to my surprise... Anyone?
    Please use plain text.
    Re: Sample Line Stationing Text Not updating
    01-14-2013 01:18 PM in reply to: LeafRiders
    Your label style is probably using the Sample LIne name to display. Change this to use the Sample Line Station Value. The name does not change when you move the Sample Line.
    Valued Mentor
    LeafRiders
    01-15-2013 09:33 AM in reply to: Jeff_M
    Here I thought the default was set to that in first place. Thanks for the tip, that worked.
