• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Sag and Crest profile labels keep disappearing
    439 Views, 29 Replies
    12-18-2012 06:28 AM
    I have C3D 2013 and recently my profile labels for sag and crest vertical curves are disappearing.  When I first open the drawing and the program goes through loading I can see the labels but once it stops loading they disappear.  All my levels are on, I have ran an audit several times, I have deleted the labels in the manager and replaced them but once I save and quit they are no longer visible.  I am able to see the labels through an xref of the drawing but it appears that the labels have been reset to their default position and not where I had adjusted them to view them within the viewport.  I have attached pictures of what it looks like.  Can someone tell me what's causing this and how to fix it?
    Scott
    Please use plain text.
    Re: Sag and Crest profile labels keep disappearing
    12-18-2012 06:56 AM in reply to: ssaigeon
    Looks like you are using 2013. Can you please list your computer specs, specific version of autocad and whether or not this happens on one machine or multiple?
    -Dustin
    Civil 3D 2013 64 bit SP1
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    NVIDIA Quadro FX 580
    explodetheblock.wordpress.com
    AllenJessup
    12-18-2012 07:04 AM in reply to: ssaigeon
    Please verify that ALL layers are on and thawed. It sounds like there is a layer frozen but you said they were all on. Once you confirm that that's not it. We can try to think of something else.
    Unfortunately I'm still on 2012. So I can't test it directly.
    12-18-2012 07:13 AM in reply to: ssaigeon
    Civil 3D 2013 64 bit SP1.1 - version 10.0.1464.0
    Windows 7 Pro 64 bit
    Intel Core i3 - 3.30 GHz
    8GB RAM
    AMD Radeon HD 6450
    As of right now I am the only person running this program here so its just on my machine.  I have all of the layers on and thawed.
    12-18-2012 12:24 PM in reply to: ssaigeon
    I have been working with this drawing for a couple months now with no problems until now.  Do you think the recent update could have had something to do with it?
    AllenJessup
    12-18-2012 12:40 PM in reply to: ssaigeon
    It's possible. There are a couple of recent post dealing with DRef problems. But you didn't mention the profile being a Data Reference.
    12-19-2012 10:17 AM in reply to: AllenJessup
    I tried creating a new profile view and placed it near my first profile view (that has missing profile labels).  The labels showed up in my new profile view but when I saved, closed and reopened the drawing the profile vertical curve labels were missing like in the first profile view.  As I said I can see the labels through an xref that I have and I wouldn't mind this problem so much if the labels remained where I had placed them, but they get reset to their defaut insert position after a save and close of the profile drawing that the labels are in.  I am running out of ideas, anybody able to help?
    Valued Mentor
    LisaPohlmeyer
    12-19-2012 01:26 PM in reply to: ssaigeon
    Would you mind posting the drawing so one of us can take a look?
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    12-20-2012 08:48 AM in reply to: LisaPohlmeyer
    My drawing is too large to post. Like almost 5 MB.  Know of a way around the max file size?
    Update: I seem to have found a way around my problem but I am still curious as to what is causing it.  I locked the layer that the labels are on and it seems to keep my labels displayed and how I have arranged them.  But if I unlock the layer, save, close and reopen, the labels will not be displayed.
    Distinguished Contributor
    01-16-2013 07:31 AM in reply to: ssaigeon
    I have this same problem with ALL my 2013 drawings on every machine.  It's definitely a problem when you've customized several labels.  Have you found any other work-arounds?
    Sandy W.
