• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    SURVEY CODE OFFSET
    421 Views, 12 Replies
    09-17-2012 06:17 AM
    I am just beginning to use the Survey features in Civil3D 2012 to generate a base map.  When we use the offsets, we are having issues when we have a negative number: BC ST H-.5.  The line will not offset, it just comes in directly on top of the original line.  When we use a positive number, it offsets correctly: BC ST H1.4 V.1.  Is there a setting somewhere that needs to be changed for it to read the negative numbers?  Thanks.
    Please use plain text.
    Valued Mentor
    Re: SURVEY CODE OFFSET
    09-17-2012 09:05 AM in reply to: lbraff2648
    Even though this fuction exists I rearly use it. However, try adding a V0. My thoughts our that it is looking for a vertical offset as well and that is why nothing happens.
    09-17-2012 10:26 AM in reply to: rl_jackson
    I tried adding V0.0 and it didn't work either.  Thanks.
    Valued Mentor
    09-17-2012 10:57 AM in reply to: lbraff2648
    OK,
    I ran a quick test and do not exhibit this issue. Below is how I had it set up
    1000,760086.2853,2435408.5935,555.2727,BC1 BEG H-0.5
    1001,760083.5208,2435435.5897,555.2210,BC2 BEG H-1 V1
    Added: I am running SP2
    *Expert Elite*
    AllenJessup
    09-17-2012 11:03 AM in reply to: rl_jackson
    I see one difference between your example and the OP's. You used -0.5 and the OP used -.5.
    So I'd suggest the OP try -0.5 instead of -.5.
    Allen
    Valued Mentor
    09-17-2012 11:10 AM in reply to: AllenJessup
    That very well could be it, I alway but that 0 in front out of habit for less confusion, but maybe its required.
    09-17-2012 11:12 AM in reply to: rl_jackson
    This one offsets to the right correctly:
    134,7014363.181176,11836190.984148,394.089449,BL ST H1.4 V.1
    This one doesn't offset to the left, it's directly on top of the original line:
    104,7014263.834784,11836296.056239,394.991292,BC ST H-.5
    I have several others that are doing the same thing.  I don't know what is going on.  I thought maybe it's a setting somewhere that I need to change, but I have looked in Help but couldn't find anything.
    I am now thinking that I could be the custom Point File Format that we created to bring in Field Notes with the survey point labels.  It was to read any number after the "-" as another column, instead of a negative number.  I now have to figure out how to change that.
    Thanks again for the help.
    09-17-2012 11:13 AM in reply to: AllenJessup
    Adding that additional "0" didn't work.  Thanks.
    09-17-2012 11:52 AM in reply to: lbraff2648
    We regularly use codes such as: FC ST H-.5 V.5 H1.5 V.1275 for having the back of curb to the left of the figure and the gutter to the right.  This doesn't cause us any problems, so I'm not sure what is happening on your end.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    Valued Mentor
    09-17-2012 12:53 PM in reply to: lbraff2648
    I would recommend that you try the OTB PNEZD format and see if that works.
    AND / OR you need to remove the dash from your format and replace it with another character line # $ ! or something.
