AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: SURVEY CODE OFFSET
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the Edit Linework Code Set, I changed the Field Code Escape from "-" to "+" and now the offsets are coming in correctly. Thanks to everyone for the efforts.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
"I am just beginning to use the Survey features in Civil3D 2012 to generate a base map."
If you are just beginning, Im not quite sure why you would make such drastic changes to the OOTB Linework Codes, if you did not know what you were doing to begin with, and the consequences of those changes in other areas of the software. I would recommend using the OOTB and refine as you go along, I did things like changing the BEG to B and the END to E, (could be thinking about fbk here). But keep it simple. Not sure of the size of your shop but change to linework codes not only affect you they affect the field guys too. If you had a seasoned party chief that knew what he was doing with regards to codes, making such drastic changes could greatly effect productivity in the short term.
Just my Opinion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With the special codes that our survey crew uses and the settings we are using the the office, this fixed our problem without causing any issues with the survey crew. I appreciate your input.
