• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    SAC converge after a switch
    110 Views, 1 Replies
    10-28-2011 11:23 AM
    Using the subassembly composer.
    I have created a switch for 4 different curb style geomtries.  Switch works great.
    After the switch, I want to bring the branches back together.
    I want the next point to be common.  Trouble is, I have 4 possible origins.
    How do I validate the origin for this next point?
    C3D 2012
    Please use plain text.
    KMercier_C3D
    Re: SAC converge after a switch
    10-28-2011 11:29 AM in reply to: kevinjackman
    Posting a screenshot of your current flowchart would be helpful. If you are using the same numbering system in each branch you would use the same Point Number for the common point and then you can reference that point number for the remainder of the geometry.
    Kati Mercier, P.E.
    Co-author of "Mastering AutoCAD Civil 3D 2013"
    AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
    AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
    AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
