• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    SAC-Enumeration_Example
    163 Views, 4 Replies
    11-09-2011 08:27 AM
    All,
    I was looking through the "Enumeration_Example" file and want to create a similar one but wasn't sure how they setup an input parameter.
    How did they set the Barrier type to "BarrierType"?
    Also does the list for default Value come from the switch? It's A,B,C or D in the example, but I tried to switch it to 1,2 or 3 after the switch without luck.
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    Please use plain text.
    KMercier_C3D
    Re: SAC-Enumeration_Example
    11-09-2011 08:31 AM in reply to: klugb
    The BarrierType was defined by going to the View menu and selecting Define Enumeration. There you can create the Enumeration Group (ex. BarrierType) and the Enumeration Items (ex. A, B, C, D)
    Kati Mercier, P.E.
    Co-author of "Mastering AutoCAD Civil 3D 2013"
    AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
    AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
    AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
    *Expert Elite*
    11-09-2011 09:01 AM in reply to: KMercier_C3D
    Great,
     NOW I know what I'm looking for I found it in the help files.
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    11-09-2011 01:10 PM in reply to: KMercier_C3D
    Ok, now I have a different issue.
    I have been getting errors with my version of the subassembly that I built from the example. I went back and tried the original one and still get the same errors so it's either my computer or the code has always had an issue.
    Have you (or anyone else watching) used the "Enumeration_Example.pkt" downloaded from Autodesk?
    I get " [FooterWidth (Double): 301 : Value cannot be null." error message.
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    11-09-2011 02:12 PM in reply to: klugb
    Never mind, found it. It was an issue with the original code:
    http://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/66/message-id/158355/print-single-...
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
