AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Rotate multiple text objects 180 while retaining individual insertion points?
- Highlight
- Email to a Friend
- Report Inappropriate Content
Short Question: I have numerous text objects I want to rotate 180 while retaining each text objects insertion point. There's got to be an easy way to do this.
Long explanation: I created an annotation template to label pipe diameters on an imported shapefile. Everythings good, labels are parallel with lines, except for the fact that some labels are upside down. Is there an expression that would eliminate this? In my annotation template, my rotation expression equals the "angle" field of the object. My "quick and dirty" fix was to burst the annoation labels, and manually rotate necessary text, which wasn't a huge headache since I'm dealing with a relatively small number of labels, but in the future I might have hundreds of upside down labels.
Any thoughts or suggestions?
Re: Rotate multiple text objects 180 while retaining individual insertion points
- Highlight
- Email to a Friend
Look into the "plan readability" of your labels, that should have fixed it.
For the question about text, I suggest you ask in the Lisp forum. Or just search in it. It's probably been done before.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Not sure if this will help, but you can also try 'flip label' or 'reverse label' in the menu that comes up in the ribbon when you select the label.
David E. Henderhan, PLS
Infrastructure Design Suite 2013
Dell Precision T3600 - Windows 7 64-bit
NVIDIA Quadro 600
Intel(R) Xenon(R) CPU E5-1607 0 @ 3.00GHz 3.00GHz
8 GB ram - Two 1TB raid
- Highlight
- Email to a Friend
I did a little further research and found a LISP that rotated text accordingly to make it plan readable. I think thats the quickest way to resolve my problem, so I'll take it.
Thanks for the input guys, I was steered onto a LISP that would have come in handy over the years.
