• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    Valued Mentor
    sjg
    Re: Rotate drawing in viewport
    12-06-2012 12:39 PM in reply to: rvandever21
    I use ALIGNSPACE, which is also in the express tools, in the Layout Section. Very easy to use.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    12-06-2012 01:32 PM in reply to: LeafRiders
    LOL
    Lets start a UCS rebellion!:smileysurprised:
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    12-06-2012 01:33 PM in reply to: rvandever21
    Another option is to just rotate the viewport. It's super easy. The view will be rotated. The viewport will appear to be rotated, but it's not, it's clipped. You can remove the clip after if you wish. VPROTATEASSOC setting is used when rotating viewports.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Valued Mentor
    12-06-2012 04:21 PM in reply to: mathewk
    Matt, they could try the rotate command too (grin)
    12-07-2012 04:17 AM in reply to: rvandever21
    Also make sure your viewport isn't locked.
    "The source of expertise is not in the memorization
    of the minute details of a subject but in the thorough
    understanding of the fundamental concepts on
    which it is based." - Dan Appleman
    Distinguished Contributor
    doni49
    01-04-2013 08:59 AM in reply to: rvandever21
    This is a lisp routine that I use to DVIEW rotate my modelspace work.  It makes it so much easier.  Assuming you're alignment is one tangent, you'd pick one end then the other end.
    That will be made horizontal to your viewport.
    (defun dtr (x)(* pi (/ x 180.0)))
    (defun rtd (x) (* x (/ 180.0 pi)))
    (defun c:dvtwist()
      (setq pt1(getpoint "Select the first point:  "))
      (setq pt2(getpoint "Select the second point:  " pt1))
      (setq ang(angle pt1 pt2))
      (command "Dview" "" "tw" (- 0 (rtd ang)) "")
      (setvar "snapang" ang)
    *Expert Elite*
    01-04-2013 09:57 AM in reply to: doni49
    Here is a lisp someone else posted elsewhere on the forums.
    Like the last one, it sets the DVIEW TWIST and the SNAPANG  so that your crosshairs & ortho work horizontally to the screen.
    This one lets you pick two points, or select a line, block, or text to use the rotation from.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
