AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Rotate drawing in viewport
- Highlight
- Email to a Friend
How do I rotate the drawing in viewport?
I want to have my profile and alignment to be in the same orientation on paper space. I have VPROTATEASSOC set to 1. I am not sure if I am using UCS and MVSETUP correctly. All information will work.
Thank you,
Rochelle Vandever
Re: Rotate drawing in viewport
- Highlight
- Email to a Friend
Use two viewports. In the profile viewport, no rotation at all. In the alignment viewport, use Dview with Twist option.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
I tried to use the DVIEW on my viewport. It says I could only use dview in model space.
- Highlight
- Email to a Friend
If you double click inside the alignment's viewport, you will be in modelspace (not to be confused with the Model tab.) Use Dview from there.
Redding, CA
- Highlight
- Email to a Friend
I was able to rotate the drawing but I can scale or move the drawing to line up the profile. Is there a way to keep the rotate but turn off dview?
- Highlight
- Email to a Friend
When you get the rotation right, set the scale of the viewport. Then lock the viewport to prevent accidentally changing the scale later. Both the scale and the lock can be found at the bottom right of your main screen, or in the properties pallette.
Once you've done that you can move the viewport around in paper space, and stretch it bigger or smaller as necessary.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
I just re-read your question; do you need to hit enter one more time to exit out of the dview command?
- Highlight
- Email to a Friend
I still have the dview command on but when I escape to move the drawing. The alignment will change back to the original drawing.
- Highlight
- Email to a Friend
Don't hit Escape
Hit Enter instead.
- Highlight
- Email to a Friend
This is a pretty painful solution...
Use UCS (enter) 3 (enter) click two points (left to right), this will be come your new West to East (left to right).
Final step.... Type PLAN (enter) (enter)... Proceed to set the scale of your viewport and then lock it as suggested. Good Luck!
