• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Road intersection label in profile view
    320 Views, 4 Replies
    04-10-2012 07:23 AM
    What can I do to show intersection information in a profile label?
    I mean, supose I have two roads (A and B)... what should I do to show in the road A vertical profile the name and the station of road B in the properly position of this A profile?
    example from a similar post (pdf attached):
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/LABEL-INTERSECTION/m-p/2669277/highlight/true#M129377
     Thank you a lot,
    Diego Álvares
    Civil Engineer - www.trentoengenharia.com.br
    Autocad Civil 3D 2013 - Infrastructure Design Suite
    Windows 7 64 i7 860 @2.80GHz 8GB Ram Quadro 2000D
    Please use plain text.
    *Expert Elite*
    Re: Road intersection label in profile view
    04-10-2012 08:10 AM in reply to: diegoal
    You can insert a block at the intersection and use the project object to profile view tool and select that block.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Valued Contributor
    04-10-2012 09:53 AM in reply to: mathewk
    Thanks for your reply, Matt.
    And how can I insert a block in the intersection? Should I do it manually or set it by some alignment or intersection style?
    Of course I already have an intersection object set but maybe this is not what you are talking about ...
    Thanks again and I hope solve it :smileyhappy:
    Diego Álvares
    *Expert Elite*
    04-10-2012 09:57 AM in reply to: diegoal
    No just a regular block. It won't dynamically move if you adjust your intersection.
    WISH:
    The ability to project an intersection object to profile views. Better yet, let's make this an automatic thing. Project ALL intersection objects as they are created.
    Matt Kolberg
    Valued Contributor
    04-10-2012 10:01 AM in reply to: mathewk
    That what I was afraid of...
    Later I'll try do it dynamic with visual basic :smileyhappy:
    I share your wish. Thanks!
    Diego Álvares
