• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Road design standard of Civil 3d 2005
    103 Views, 3 Replies
    05-17-2005 04:04 AM
    Hi all,
    I am using Civil 3D 2005 but when I am going to draft a component of a road ( such as corridor,) the bydefault value its taking not in our country standard (that is Indian Road Congress Standard). Can anybody know in which standard followed in Civil 3D 2005 design?
    Can anybody tell how can I get a civil 3D 2005 which works in Indian Road Congress Standard & what I have to do ?
    Please Help.
    Please use plain text.
    *Jon Rizzo
    Re: Road design standard of Civil 3d 2005
    05-17-2005 04:46 AM in reply to: animkundu
    I don't believe the defaults are set to any one specific standard. You can
    set defaults any way that you would like for just about every command or
    option in Civil 3D. Go to the Settings tab of Toolspace, right click on the
    top level drawing icon and select "Edit Drawing Settings...".
    Hope this helps,
    Jon
    wrote in message news:4846991@discussion.autodesk.com...
    Hi all,
    Please Help.
    *Laurie Comerford
    05-17-2005 05:55 AM in reply to: animkundu
    The default settings will obviously have been made by Autodesk to reflect
    USA drafting practices.
    The system however was designed to allow for local customisation by going
    through the settings options and creating values to suit your needs, then
    saving the resultant drawing as a drawing template.
    If you start every new drawing from that template, then your standards will
    be in place.
    There are hundreds of items which can be changed, so you should allow some
    considerable time to make the settings the way you need them. As you are
    looking to meet a National standard, it would seem that it would be worth
    discussing this with your dealer, to see if assistance can be given, or if a
    group task could be organised.
    In Australia, Rad Lazic has prepared a template drawing to reflect
    Australian drafting practices and this can be readily downloaded from our
    web site. Rad has updated this template on a number of occasions as he
    refines it.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    Hi all,
    Please Help.
    Active Contributor
    05-20-2005 03:20 AM in reply to: animkundu
    hi Laurie
    Thanks for your help in this issue.
    Animkundu
